via hardware monitor
Doug8521
Am running an AMD Duron 800 on MSI-K7T Pro2-A m/b and looking for the VIA Hardware monitoring program. Can Anyone direct to a site where it can be downloaded...???? Thanks for the help...
Confused
14,166
I use and recommend Motherboard Monitor, which i'm using on my Duron 700 on a KT7. i find this much better than VIA Hardware Monitor, and it also integrates with ShutDown NOW!, and if the temperature gets higher than you specify, or if any fans stop, then it can automatically shut down or restart the computer.
