VIA AC?97 Audio Controller (WDM)
i have a gateway 300s
2400 MHz.amd
winxp pro
mobo intel brownville d845 gb.
the onboard sound will not work.
there were five 5 Controllers not found ,fixed four of them .usb ,video
VIA AC?97 Audio Controller (WDM) for this comp does not seem to install right.
the gateway site is no real help.if you need my serial # is 0031502126 for use on the gateway site.called gateway ,the say mobo no longer supported with all drvs.i have no restore disk.is there a fix or a trick?
thanks folks
crown711 is online now Edit/Delete Message
2400 MHz.amd
winxp pro
thanks folks
