[vga.zol] behold epic custom amd card kit. 7 card bridge for F@H
IonusX
392
im not making this up. someone has made a custom CF bridge for amd cards that covers 7 cards at once. its designed to work with F@H but can be sued for others things (though i dont recommend it, you actually lose performance in games)
http://vga.zol.com.cn/269/2699569.html
btw what you see before you is 6 5800 series cards and a single sapphire hd 6850
BallaTheFeared
8,115
You mean custom PCI extension right? There is no CF going on there, and F@H with AMD cards is terrible, they should switch to Seti.
dajeepster
1,974
16
if that's a bitcoin miner's dream, then this must be bitcoin miner heaven:
WhoBeDaPlaya showed this to us in another thread just the other day...
actually the one by the OP is better.. it runs off of one motherboard... the one you posted is actually three setups with four gpu each.. . you can see the back plate of each motherboard.
Sunny129
4,823
so that many AMD cards should equal about 1 GTX 570 in F@H?
yep...just like that many nVidia cards equals about 1 HD 5870 in Milkyway@Home, SETI@Home Astropulse, PrimeGrid, and Collatz Conjecture...
well i suppose i should have included an "if money were no object" disclaimer ;)
