VGA too hot?
DMXSNOW
79
I wasn't playing a game and my VGA temp. rose up to 49c(about 100F), it started beeping then went off, went down to 45 then back up and beep again.
(Nvidia 6600GT)
Anyway to fix this or updates that im not aware of?
imported_java
23
49C isn't that hot. A fan would be pretty obvious if u opened up the case. The VGA would be the highest card. I would also try updating video drivers
stevty2889
7,036
8
What are the rest of your system temps? Are you sure it was the video card that was causing the beeping? 49c is definatly not too hot for your video card temp. Go to your video card driver settings, and look under the temperature settings tab, to see what it has for limits.
