So, this is probably going to be a looong question, but I'd really appreciate the input of the Anandtech braintrust.
I have an ageing Core Duo laptop that I've been using as a media center. (It's a Dell 6400 with a T2400 CPU - not flashy, but good enough for me!)
Unfortunately, the VGA output suddenly stopped working. Suddenly my TV just said "no input" on the VGA port. (I know it's the VGA output that's the problem, because I've used another Laptop to test, and that throws output to the TV just fine - as a side note, if anyone knows how to fix the VGA output on an old Dell, they're very much invited to participate in this discussion
Anyway, the question is - what to do now? The laptop itself is fine. It plays what I want fine - but it's pretty useless if I can't get it onto my TV.
One option is something like the WD TV Live - it's the equivalent of about 150$ where I live, so not exactly cheap... But not a bad solution, other than me now having yet another thing to plug in.
I've also been looking at external video cards, but they're pretty expensive - again, around 150$, and it somehow seems wrong to spend that much on a fairly knackered old laptop, and not even get HDMI in the process...
I've also considered taking cannibalizing it for parts, and building a desktop with what I have. (I have some spare parts around that means I basically just need a motherboard and a video card). But, I'm having a hard time finding Socket M motherboards in a reasonable price-range. (The one I found was around 220$! Insane.)
Lastly, I could try to sell the laptop for scrap and get a media-center in the form of an Atom + ION combo or something similar. This is pretty expensive, and I don't know if it plays nice with MKV files and similar which is a must...
There might be even more options I havn't thought of - and I'd welcome thoughts, ideas, musings and even the occasional limerick!
Thanks in advance!
Thanks in advance!
