Onboard video. The only thing those apps use 3D acceleration for are real-time preview or draft modes. Final rendering is done by the CPU.Originally posted by: dvr
what vga card(with the best performance/price ratio) do u think will be sufficient to do tasks such as 3dmax, autocad, and sketchup?
Onboard video. The only thing those apps use 3D acceleration for are real-time preview or draft modes.Originally posted by: dvr
Originally posted by: SonicIce
is there any point to workstation cards?
hm, means i don't have to use vga for now?
i'm thinking of getting mobo biostar TA790gx, it has AMD 790GX Chipset with ATI Radeon HD 3300 Graphics..
Depends on what you are doing and how large your models are. Again, if you are just playing around as a hobby with a few thousand polys then, sure, whatever will work. When you start to add textures and get into the several hundred-thousand poly models you are going to be hating life.
ic, i'm architecture student now, wanna learn 3dmax, of course there'll be rendering things..
is 4830 ok? or should i just use 4850? i wanna get the best out of the cheaper..
Admittedly, integrated graphics is a bit overly optimistic for applications with the CPU and memory demands of 3ds Max and AutoCAD. Even modern IGP are going to cut into available memory bandwidth and host CPU time that may be better used for non-graphics application loads, and vice versa. I shouldn't have been so cavalier, but the 3D acceleration features ARE fully supported, even by something as lowly as GF 6100. Here is the difference that driver and application optimizations make:i tried on-board video since i like the micro-ATX form factor for 3D Max computers, and most or all micro-ATX boards have on-board video. there's a noticeable difference just opening the aps. once you have geometry on the screen, it noticeably bogs down. that was with XP32, an opteron dual core, Max 9 - and the 6150 chipset.
From AutoDesk on 3ds Max, which utilizes significantly more GPU acceleration than AutoCAD (applicable to 2008/2009/2010):Originally posted by: sgrinavi
Both AutoCAD and Max extensivly use the 3d acceleration available in a workstation card, Max IS a 3d program, that's about all can do with it. AutoCAD has some great 3d capability that you use, especially when you are exporting stuff over to Max.
I repeat: "The only thing those apps use 3D acceleration for are real-time preview or draft modes. Final rendering is done by the CPU."Some features of 3ds Max 2009 are only enabled when used with graphics hardware that supports Shader Model 3.0. The features that are impacted are:
[*]Interactive previewing of shadows: Provides users with the ability to see real-time shadows casted from the lights in the 3ds max viewport, hence allowing for previewing.
[*]3ds Max sun/sky environment: Allows users to see real-time mental ray Sun & Sky background in the 3ds max viewport. The viewport background will also update.
[*]Mental Ray Architectural and Design material: Allows users to do real-time previews of mental ray Architectural & Design Materials in the 3ds max viewport.
Although these applications do utilize the 3D pipeline, it is very baseline acceleration. AutoCAD, 3ds Max, Catia, and other design applications have been using baseline acceleration features in combination with CPU rendering very effectively for years to create the impression among uninformed users that there must be a lot of "advanced" 3D acceleration going on, when it just isn't true (and has been proven over and over even by the application developers).Originally posted by: dvr
i don't have the computer rite now...n wanna build one, my thought: Phenom II X3 720BE, 4gig RAM, biostar TA790GX, GPU? no idea yet..
granted, there's different on-board GPU's & some of them are pretty good.
as long as the computer has a PCI-E video card connector, it almost doesn't matter. you can always add a video card.
Here is a pretty good deal on an HD 4650:
POWERCOLOR Radeon HD 4650 512MB 128-bit GDDR2 PCI-E X16 - $41.00 plus shipping AR
However, you may want to seriously consider going with a workstation card:
Consumer Gaming Versus Professional Workstation Card Performance : Radeon HD 4870 Versus FirePro V8700
That's dependent on the price. Newegg's prices seem to change every day. HD 4650 and 4670 are the same GPU with different clocks and memory. Here is an HD 4670 for $10 more (while the price lasts):Originally posted by: dvr
4650? how about 4670? http://www.techpowerup.com/rev...rcolor/HD_4890/31.html tells that 4670 has better performance/dollar ratio..
They're useful if you like bragging about how much you pay for stuff. Gaming cards do horrible in synthetic benchmarks:Originally posted by: SonicIce
The last thing we can say basing on the obtained results, is that gaming graphics cards can also demonstrate good performance in contemporary CAD and CAM systems. The situation has changed: the top gaming graphics accelerator we took as n example this time ? GeForce 9800 GTX ? was completely defeated by its professional opponents only in one synthetic SPECviewperf testing suite working with an OpenGL driver. In real applications the systems equipped with this card performed very well. Moreover, in some tasks such as SolidWorks 2008 and AutoCAD, it worked even faster than 100-dollare professional solutions.
How ironic.I would like to point out that Nvidia offers not only basic drivers for its professional solutions. You can also download two additional utilities compatible with Quadro FX from the company web-site: MAXtreme D3Dand Powerdraft. These are specialized drivers for Autodesk 3ds max and Autodesk AutoCAD. These special drivers help boost the professional graphics cards performance in the above listed CAD applications.
Someone obviously has never touched a real professional workstation or design application, and I think we can all agree who that is.
What you left out is how important those previews are. If I have to move a light, then render, change a material then render everytime I change something that is going to consume lots of time vs change something and see it instantly in the viewport.
3dsmax2010 makes extensive use of the GPU . It isn't just geometry speed improvements in viewports anymore. Use too low end a card on Max 2010 and you will lose a lot of features. When you can get accurate lighting and materials in a viewport without ever having to render a frame that is a huge time saver. Max2010 viewports are unlike any application before it except Mudbox which does even more with the GPU.
Watch the video:
http://usa.autodesk.com/adsk/s...teID=123112&id=7658360
hm., quad core? is X3 720 BE okay? it's cheaper than intel E8xxx ones.
