I have an old TNT2 Ultra card that has a damaged hsf and thous doing a lot of noise. If I change the stock one and get e.g a blue orb will it fit on the board? Also should I apply anything between the chip and the hsf?
the satisfaction rating for the blorb varies tremendously. another hsf you can consider is the Tennman lasagna. it's small & effective & comes with a thermal pad! 🙂
