VGA cable with removable ends?
Gunslinger08
13,234
Do they make such a thing? I'm trying to feed a VGA cable through a thin tube which the connectors won't fit through.
bwnv
419
I've never seen one. You might try getting a VGA extension cable and cutting the ears (where the screw goes through) off of it. At least that way if it doesn't work yyou haven't borked your CRT cable.
networkman
10,436
If you click HERE you'll get a description of how to run a VGA signal over Cat5 cabling - that should take care of your "thin tube" issue. :)
Gunslinger08
13,234
Any idea where I could buy a kit for that? I don't want to solder.
Zepper
18,998
What is it you're trying to accomplish? Perhaps there is a better way than the one you're planning. How small is the tubing (inside diameter) and how long does the cable need to be?
.bh.
networkman
10,436
You must come from a different school; I was always taught that learning to solder well is a character building skill. :cool:
