This is my first time posting to these forums, I searched all over but can't seem to find a straight answer for my issue elsewhere, so here goes:
For the past 2 years or so I have had my PC hooked up to my HDTV with a 6' VGA cable with the resolution at 1080, HD, no problems. Recently my daughter has started crawling about so I had to move the PC away from the TV and further off the floor. I went and ordered a 25' VGA cable off Amazon, in fact, the one here:
http://www.amazon.com/Premium-VGA-Mo...9454505&sr=8-3
When I use the new cable, the PC no longer recognizes my HDTV, and instead sees it as a Generic Non-PnP Monitor, and no longer gives me the option of displaying at 1080.
Just to be sure nothing hardware related occurred, I tried the 6' cable again, and it went back to 1080, recognized the HDTV and all was ok.
So I know it's the cable - my question is this - Is it the cable that is the problem or is it the length? Do I need to get a different cable or do I need a signal booster?
(Before other alternatives are given, no, I don't want to use a HDMI cable. It actually does not look as good as using the VGA cable - which is weird.)
(Also, before anyone tells me VGA cables can't do 1080, please go look around and see that you're wrong before telling me that the cable I have can't provide the resolution it has provided for 2 years.)
Thanks for any help!
