OK, I have had my new system running for over a week now, no issues to speak of till now.
Then, last night I was playing Diablo II: Lord of Destruction (that game is still real fun), and the display went weird (lots of yellow dots in a grid. I will try get a screenshot, coz I dont know how to describe it in less than 10000 words).
Now when I turn the computer on, I get 5 vertical lines of dots (not continuous, but a fair few dots per line. This dissapears at teh next screen, and doesnt show in BIOS either. Shows up again when XP is loading, and then when in Windows, just some icons dont show, and I get some dots by the cursor (moves with the cursor).
Any ideas? I reset BIOS to defaults, and it still happens. Im thinking maybe I overvolted something, but I dont really believe thats the cause (voltage was lower than what others have run I know)
So, the specs:
Opteron 165
DFI SLI-DR Expert
XFX 7900GT (non voltmodded)
2x1gig OCZ EL Platinum
WD Raptor 74gig
Seagate Barracuda 300gig
running XP Pro SP2
CPU was at 2790 I think (have been playing with it anywhere between 2700 and 2799, definately stable at 2745) at 1.475 x 1.048 volts, had RAM at 2.84 and chipset at 1.65 volts. Hence I dont think I overvolted anything.
Considering re-installing XP, just to see if it helps, but if this can be avoided I would be glad.
So, any ideas? Like I said, this was running fine for a week or so, and so I cant work out what has gone on (didnt change anything before this happened...)
So, the specs:
Opteron 165
DFI SLI-DR Expert
WD Raptor 74gig
running XP Pro SP2
