Ok, here's one I'll bet no one's heard before.  I can't seem to get my IBM to connect with my SMC Barricade wireless router, but my wife's Dell laptop connects with no problem, and the IBM can connect to my neighbor's wireless network with no problem.  I've had my home WLAN running for a couple of years now (and a home LAN for a couple years before that) and while I'm no JackMDS, I know my way around home networks well enough to handle mine and a few friends'/familiy members'.
Here's the particulars:
IBM Thinkpad with Intel(R) PRO Wireless 2100 Mini-PCI Adapter with most recent driver, 1.2.4.35
Windows XP Pro SP2
Dell B120 with Dell 1370 Wireless Mini-PCI Adapter with Windows XP-shipped driver, 3.100.35.0
Windows XP Home SP2
SMC2404WBR Barricade Turbo Wireless Router
- DHCP enabled
- MAC filtering disabled
- broadcasting SSID
- no WEP enabled
(normally I run it with all four of those set opposite, but for troubleshooting purposes I opened the sucker up)
1) I turn on the wireless broadcast on the router, boot up the Dell, it automatically connects to the WLAN and I'm surfing effortlessly.
2) I boot up the IBM, and bring up the WinXP Wireless Zero Config utility - it can "see" the fact that my WLAN is there, so I select it and click "connect".
3) It tries to connect for a few minutes, then the "waiting for wireless network" dialog goes away with no success/failure message, and my WLAN has an "Automatic" next to it in the "Available wireless networks" window. But it's not connected 'cause the taskbar icon says so, I can't surf, and I can't ping the router.
4) Repeat step 3 multiple times after rebooting IBM and router - no change.
5) I see my neighbor's unsecured WLAN in the "Available wireless networks" window, select it (with the IBM) and click "connect" - it connects in less than a second and I'm surfing merrily away (though with quite a weak signal). Repeat with Dell and get same successful connection.
6) Try my own WLAN again with IBM - experience same failure.
7) Disable the WinXP Wireless Zero Config utility (on the IBM), install Intel's PROset software, latest version 7.1.4.5 for the 2100 adapter.
8) After confirming that the WinXP Wireless Zero Config utility is no longer usable to connect to WLANs, repeat steps 3-5 using Intel's PROset software. See same results for both WLANs (mine=failure, neighbor's=success).
9) Start laughing hysterically in frustration.
10) Post to AT.
Um, help?
Thanks in advance,
Jason
Windows XP Pro SP2
Windows XP Home SP2
- DHCP enabled
- broadcasting SSID
- no WEP enabled
10) Post to AT.
Um, help?
Thanks in advance,
Jason
 Facebook
Facebook Twitter
Twitter
