So I turned on my computer and everything was fine. I went AFK for about an hour, and when I came back, something happened (dun dun dun). I saw a blue screen that looked like the Windows XP setup screens and it said "One of your disks needs to be checked for consistency." I thought maybe this was just some sort of bug or usual error, so I just tried manually restarting my computer. Before the Windows loading screen appeared, that bluish screen appeared again stating "one of your disks needs to be checked, etc" again. I thought it was maybe a normal CHKDISK routine, so I tried skipping it by pressing any button to skip. When I tried to logon Windows for the next few tries, it froze several times right after entering my password.
After manually shutting down the computer and turning it back on, everything worked fine again. However, when I logged back onto Windows, ALL my desktop settings (all my files on desktop gone, background gone, icons gone, only default and some program icons were there) were erased and purged. The programs and start menu files were strangely ordered and it seemed like a lot of programs were gone or missing. I also noticed all my settings were gone on everything. Internet Explorer's favorites (doh! should have backed up) were gone and pretty much EVERY SETTING of the computer that I originally saved, were gone.
It almost looked like a new copy of Windows except there were still SOME (because I think half of them were erased from start menu) existing programs that I had installed before. They were still there, just not showing up on desktop. It almost looked/felt like if System Restore (which I had turn off) did something or my computer reverted back to a "default" desktop in which everything was new again, but old files remained; just that the user settings were gone (wtf).
Now I thought I was really screwed because I thought all my files were erased and everything else that I had. But to my surprise, all my program files and desktop files were still there. I found my desktop files to be in C:\documents & settings\name\desktop. It's just that the other settings were erased. Every program I opened like MSWord felt like it was brand new, asking me stuff like "Name and Registration". IE, itself, also reverted back to default, deleting all my cookies/favorites/etc...
After this, I begin getting some of viruses/trojans which I quickly erased. Since my original programs like HijackThis and my virus scanners were there. I quickly scanned my computer and found several ones and then deleted them. All this strange mess leads me to several questions:
1. What exactly just happened?! Was it perhaps a trojan/virus that somehow took over the computer and deleted all the settings? What trojan could possibly do this? Or was it truly a main HD failure (possible dying HD?) or bad sectors? Everything else was fine. I went AFK for awhile and came back and my computer had gone into the blue screen where it was *already* in progress of "checking disks for consistency." I have two HD's, one with all my main program files & WXP, and the other with media. Anything to rule out one problem or another?
2. Can my old desktop settings be recovered? Or ANY setings at all? If I go to my C:\Docs & settings\name\desktop, all my files are there, but it doesn't overwrite anything. For example, if I try to edit anything in my old folder desktop, it wouldn't appear in my NOW NEW desktop.
Any suggestions to try to rule out or attempt to fix? Strange problem, indeed. Thanks.
 Facebook
Facebook Twitter
Twitter
