very simple question on k7s5a! PLESAE!HELP!
LongCoolMother
i disconnected the power button cable to one of the jumpers on my motherboard. i cant find the jumper! i looked in the manual but it didnt tell me! please someone help! i cant power on my cmputer now! where is the jumper located/labeled! thanks in advance!
check pg 14 of the manual, very bottom shows graphic of FP1 header... If yours doesn't show this, the correct pins for the power button are P6-8. That is, the bottom two pins on the right side of the header.
Hope that helps 🙂
