Hi all,
I've got some serious problems with this pc, and I'll have to make this post fast seeing how it can crash at any moment.
Specs:
AMD Athlon 64 3000+
MSI K8N-Neo2 Platinum Nforce 3 Socket 939
Tsunami 400W PSU (+3.3V = 28A, +5V = 40A, +12V = 17A)
OCZ Performance Series 512mb DDR400 Ram (CL 2.5)
Galaxy Geforce 6600GT
Sound Blaster Audigy LS
Maxtor 20gb 7200RPM IDE
Pioneer DVD Burner
The Problem:
- Everytime the computer is shutdown from windows (or by disconnecting the power cord) I am unable to turn it back on using the button. I must open up the computer and reset the CMOS via jumper. Only then, after I plug the power cord back in will it turn on.
- At seemingly random times the computer will turn off, and I will be unable to turn it back on without resetting the CMOS. I have no idea why it does this at all. No viruses found on the PC. Only thing different about this in comparison to a normal shut down is that when it turns off the Power Led at the front of the case blinks on/off. The computer does not seem to be in any sleep or suspend mode.
- At seemingly random times the internal speaker/beeper will just go off and emit a contuous beeping sound (no intervals, just beeeeeepppp). The computer begins to freeze at that point and the only remedy is restarting it.
PLEASE NOTE: If I restart the computer from windows, or just use the restart button on the case, it will restart with no problems!
At first I thought this was all heat related, but I also found this very unlikely. The computer was operating with minimal problems for about 3 months before this happened. There are two 28CFM intake fans (one front one side), one 34CFM exhaust and the powersupply exhaust fan.
I monitored my temps constantly and found that peak CPU temp was aboput 42 degrees and peak system was about 32 degrees.
I contacted MSI about only the bios shutdown problem (not the other two), they told me to test it with a different PSU. I do not have a spare one, so I was unable to do this. They also told me to reflash my bios, which I did to no avail.
This all happened after my CDRom drive died.
Suggestions anyone?
Specs:
AMD Athlon 64 3000+
Pioneer DVD Burner
The Problem:
Suggestions anyone?
