- Nov 19, 2007
- 2,793
- 2
- 0
My explorer.exe is f'ed up somehow. It works fine, I can rename and move and delete files at normal speed.
If I rename a file, explorer will become unresponsive for a while. But if I open up another window and go to the same directory, the folder is already renamed.
Pop-up windows (deleting, moving, recycling) take a long time to go away even though the file is deleted, moved, or recycled almost instantly.
The problem started today. I had my drive laid out like this
Partition A: Windows
Partition B: Applications.
I uninstalled all the applications, deleted Partition B, resized Partition A, and reinstalled all my applications. Then the problem started.
Firefox is also unresponsive when opening pages. (after reinstall) Safe mode didn't help.
