Very odd problem...
MAME
Banned
I'm working on a spyware infested laptop and I ran spybot and adaware to start with. The computer crashed in the middle of the scanning and after restarting it's completely f'ed up. Any exe file I try to run says, "This file does not have a program associated with it for performing this action. Create an associate in the folder options in Control Panel"
But, as far as I know, .exe's aren't listen in the folder options file association section. How in the hell do I get exe's to run?!
How long since it got infected? If you know the approximate timeframe you may try to run a System Restore instead.
Originally posted by: Zolty
just reinstall XP, it will be way easier in the long run.
I tried to actually. It had an error when trying to boot off the cd. This computer is totally crazy
I managed to get the spyware off and it's decent now. Much faster in the long run actually
