I have a WinXP SP1 installation, i875p-based system.  I use Acronis True Image - have been for about a year now.
I originally had 2 PATA drives installed and am adding a SATA drive that I would like to now boot from. I enabled sata in bios and booted up to make sure the driver was installed. I then booted from the Acronis bootdisc, used the disk clone option to copy the partitions from the current PATA system drive to the new SATA drive.
For the first boot, I unplugged the old system PATA drive and all worked fine!
For the second boot, I added the PATA drive again, and it booted from IT instead of the SATA drive.
I pulled up PartitionMagic and formatted the old PATA drive. When it was done, it booted, definitely from the SATA drive, but I get something like the following error:
A problem is preventing windows from accurately checking the license for this computer Error code: 0X80090006
I can't get into Safe Mode. What's going on here? I really don't want to start over again!! Looking at the drives from Acronis Boot disk, the old system drive still appears to be an primary/active partition, as well as the new sata drive. How can I remove this from the old drive, and would that even help?
 Facebook
Facebook Twitter
Twitter
