I have a P45 GA-EP45-UD3L motherboard in my HTPC. It has a very odd problem with attached hard drives. Occasionally it will hang at some point during the boot process, typically on the gigabyte splash screen. When I go into the BIOS I noticed that it is detecting the hard drive on two different channels: 1 and 4. The drive shows up twice in the boot priority list as well
If I move the drive - the old unused phantom detection goes away but the previously detected channel becomes the phantom drive
Ex: it was in channel 1 and was detected on 1 and 4
I move it to channel 2. Now it is detected on 1 and 2
There is no way that I can see to specifically turn off the channels in the BIOS but if I turn auto off on the channel the problem goes away for 5+ boots but then it will return.
Any ideas?
Any ideas?
