Ok.. I have an MSI K8T-Neo motherboard, Athlon 64 3000+ CPU, and (2x) SATA hard drives in the following air-flow configuration. Intake: (2x) 80mm in font and (1x) 6" x 6" Fan that I mounted into three empty 5.25" bays. Outflow: (1x) 80mm fan in the acrylic window, (1x) 120mm fan on the top, and (2x) 80mm fans on the back. Also, I have artic silver 5 on my CPU. Yet for some reason when Idle my CPU temp is at 55 C. (131 F.) is this normal? Im not sure of the normal heat output of an Athlon 64. And if not, any siggestions?
