Very embarrassing C++ problem
gamepad
1,893
I posted this in another forum, but I think that forum might be dead. I decided to bring this problem to the attention of Anandtechers (w00t!).
I am just beginning my adventure into the world of programming and am having trouble with C++.
Whenever I copy paste example programs into Dev-C++ and compile and run, I only see the program for a split second before it disappears. If the program has input, it allows me to input information, but then it disappears again.
Look at this program for an example:
#include <iostream.h>
int main()
cout << "Hello, World!" << endl;
return 0;
When I run the program, it just flashes for a fraction of a second and disappears.
I'd be very grateful if someone can help me with this woe.
Idontcare
21,110
59
What exactly did you want it to do? Print "hello world" and then "hang" for a while with this message on the screen?
If so then you need to add a wait/pause/loopwhile-count or some such, otherwise the program appears to be doing exactly what you programmed it to do - print hello world and then close thereafter because all the code has been executed.
brandonb
3,731
If you run it from a command prompt (the .exe after it compiles) it will display and bring you back to the command prompt when exiting.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Every command line noob has that problem.
Welcome to the world of Windows/DOS box programming.
gamepad
1,893
Oh.. that makes sense. Good thing I have about a week of Linux experience under my belt. :)
statik213
1,654
Originally posted by: tfinch2
getchar() is your friend.
If it is not clear, throw a getchar() at the end of your program. This function call will wait until you press a key and return that key's value. So this should give you some time to see your output.
dababus
2,555
Borland C++ 5.0
#include <stdio.h>
int main()
getchar();
return 0;
Aikouka
30,383
912
Or if you open a command prompt first, the window will not automatically close :p.
exdeath
13,679
10
Or you can just set the IDE flag that keeps the DOS box open after program termination instead of modifying your program...
gamepad
1,893
How do I do that?
