simple problem, i just havent seen this before so i want to make sure im singling out the mainboard properly
system was sold and then a year later i was told "it never worked"
intel boxdg41ty
e5200 cpu (right now theres a conroe L 430 in it for troubleshooting, cpu is verified OK)
2gb gskill ram
160gb sata hdd
430 tpIII
so this thing wont power on. the lights on the mainboard light up when i turn on the power supply switch, but nothing happens when i hit the pwr button (or if i just hit the contacts manually with a screwdriver on the board)
i stick a twist tie between the green and common on the mainboard power connector, and it all lights up- cpu fan spins, case fan spins, hdd works of course....
but no post beeps or video shown.
its a bad motherboard isnt it?
(when i got this computer back, someone fucked with it because the cpu fan wires were wrapped inside the fan blades. im pretty sure the cpu overheated and im guessing this is killed the mainboard)
thanks for the insight!
intel boxdg41ty
2gb gskill ram
160gb sata hdd
430 tpIII
