Verizon keeps trying to connect cable is unhooked. HELP!!!!!
FFactory0x
6,991
Verizon keeps trying to connect with being plugged in. HELP!!!!!
My broadband is pissing me off. Its pissing me off cause when i disconnect from the interent and unhook the cat5 from my nic. It still trys to connect. I put in my xbox cable to ftp to xbox but it thinks im trying to connect to verizon but it cant. It constanly pops up dialing, redial, can connect even if i X it 1000000 times. Keeps trying to connct to verizon. How do i fix this so it will only try to connect to the internet when i want it to rather than keep trying to coonect
skyking
22,622
5,730
IE 6: tools, internet options, connection, select "never dial a connection".
You will have to manually connect after you hook it up.
