rocketpower
Hey guys, so I am an absolutely noob when it comes to things like this. I just wanted to run it by you guys to see if I set it up correctly.
Right now, I have fios 50/50. When I have my comp wired via ethernet, according to speed test, Im pulling down a good 55 / 50ish up. Problem is, my wireless performance was absolutely garbage. All my devices were getting about 15mpbs. Again this is with the modem/router that verizon provided me.
I went out and bought the nighthawk. And geez is my speed way up. Problem is sometimes I get 50, sometimes I get 20ish (which is still better than what I got with my original one). I just wanted to make sure the way I have it set up is correct. Really don't want to do anything like mess with the settings etc etc. I want to keep it as efficient as possible while keeping it simple.
http://i.imgur.com/G4Zb1Gy.jpg
At the moment, I have one one end plugged into the "WAN" port on the nighthawk and the other end is connected to the
http://i.imgur.com/dmWOqUQ.jpg
one of the four LAN ports on the modem/router verizon gave me. I tried plugging one end into the WAN on the verizon one so its WAN to WAN but unfortunately I received no signal at all.
Is this the right way or am I missing something? I mean my internet is def faster than before with this nighthawk. Just curious on whether or not I can make it even more stable.
For Verizon modem/router, it says the security was like WEP while the nighthawk is WPA2 if that matters. It seems as though I could still connect to the original verizon router as well. Seems alot slower though ever since the nighthawk was installed. Oh and when I set it up, I just did the "genie" method lol, where they did the heavy pull. In regards to IP, i chose "Get Dynamically from ISP"
Any advice?
Any advice?
