Hey i need help with vent. Whenever i connect or try to connect to a huge vent with lots of channels and people i will lag hardcore....like 25000 ping. My connection is 3meg charter cable... Idk wtf is wrong. Any help would be great ty.
What does your network connection look like? Are you running through a router? Many routers have the save problems with ventrilo that they do with peer-to-peer software: too many ports open can crap the router out.
By the way, most folks here will react much better to you if you type out your words.
