foodfightr
I'm currently modding a case that only has an 80mm fan on the front and the standard power supply fan in the back. I've also installed a plexiglass window. I'll be using a dangerden water cooling system installed inside the case. The dangerden system has two 120mm fans mounted on top of the radiator. If additional ventilation is neccesary what do you reccomend that I add as far as a fan or a vent?
EDIT: The case is fairly sealed. The door panels don't have any venting (besides maybe heat escaping through the plexi glass window) but there is some venting in the front and back of the case.
