- Oct 18, 1999
- 22,047
- 877
- 126
OK, I have a Radeon 64meg DDR card and use it in my secondary system primarily for capturing all my old video tapes and home movies and creating VCDs. I use Roxio 5.x platinum to make the vcds from standard mpeg captures. I have been doing this for a while and it has always worked fine. I have always played them back on my PC but finally got around to trying to play it back on my standalone DVD player (Pioneer DVL-909) Which is a laser disc/DVD combo player. My problem is that these discs do not play back on the 909! I know it is capable of playing vcds as I have a bunch of legitamate VCDs that play back fine. I dont know why but the vcds I make dont work on the 909 but work fine on my PC. Is it roxio that screws it up? I use namebrand cdrs. The file structure on the roxio-made vcds look fine. Its not copy protection as my home movies dont work either. I use the ATI capture SW, ver 7.1 I think. Is there a better way to make VCDS? I just use standard mpeg-1 capture, nothing fancy, no special codecs. Any help would be appreciated. Thanks.
