[VC][TT] - [Rumor] Radeon Rx 300: Bermuda, Fiji, Grenada, Tonga and Trinidad
n0x1ous
2,572
248
they really need top to bottom updated GCN 1.3 across the board. Remember in the 4800 and 5800 series they would launch the whole range on a new architecture within 6 months. that was awesome. Especially with all the new important features like HDMI 2 and VSR and freesync support.....
ShintaiDK
20,378
145
Assuming there is a GCN 1.3.
It would be odd if GCN 1.2 doesnt see more broad usage. GCN 1.2 holds quite some important improvements in terms of future gaming. Not to mention the fixed UVD that is broken in GCN 1.1.
Headfoot
4,444
641
I assume the reason AMD doesn't actually use the terms GCN 1.0, 1.1, 1.2 etc and instead refers to all of it as "GCN" is so that they can make incremental updates on each release without having to cascade the architecture through all the chips. It seems a deliberate product strategy to increment the architecture instead of big redesigns like in the days of yore.
n0x1ous
2,572
248
Yeah Tonga has a lot of what they need across the board with the exception of HDMI 2.0. I would think that would be a big feature tick box they don't want to miss on the 300 series..
PPB
1,118
168
Yeah, but then again it forces them to hamper their own featureset adoption rate. You cant expect wide support if you cant support your features across the whole lineup, this is the case for trueaudio and freesync mostly. Amd really needs to have the same uarch iteration across most of their lineup. If they still have large inventory of 290/280 chips, then start to dump them into the market, hope to gain some mkt share and ready your new product stack for 3xx series. That inventory is already sunk cost anyhow.
PS it also would make their life easier around mantle optimizations, 285 has some inconsistencies still, and imo its because the mantle driver is optimized for the other 95% of the gcn lineup which is 1.0 and 1.1
KaRLiToS
1,918
11
http://www.techpowerup.com/209719/radeon-r9-380x-based-on-grenada-a-refined-hawaii.html
The Grenada silicon will have the same specs as Hawaii - 2,816 GCN stream processors, 176 TMUs, 64 ROPs, and a 512-bit wide GDDR5 memory interface, holding 4 GB memory. Refinements in the silicon over Hawaii could allow AMD to increase clock speeds, to outperform the GTX 980 and GTX 970. We don't expect the chip to be any more energy efficient at its final clocks, than Hawaii. AMD's design focus appears to be performance. AMD could save itself the embarrassment of a loud reference design cooler, by throwing the chip up for quiet custom-design cooling solutions from AIB (add-in board) partners from day-one.
The only truly new silicon with the R9 300 series, is "Fiji." This chip will be designed to drive AMD's high-end single- and dual-GPU graphics cards, and will be built to compete with the GM200 silicon from NVIDIA, and the GeForce GTX TITAN-X it will debut with. This chip features 4,096 stream processors based on the GCN 1.3 architecture - double that of "Tonga," 256 TMUs, 128 ROPs, and a 1024-bit wide HBM memory interface, offering 640 GB/s of memory bandwidth. 4 GB could be the standard memory amount. The three cards AMD will carve out of this silicon, are the R9 390, the R9 390X, and the R9 390X2.
In other words, the R9 390x will be the real deal
RussianSensation
19,458
765
Source: 3D Center
^ Same rumours regurgitated over again. How can they state with 100% certainty that R9 390X is GCN 1.3 instead of GCN 1.2 or GCN 2.0? AMD doesn't officially name the various revisions of GCN. Remember that AMD already implemented major changes to colour fill-rate, memory bandwidth efficiency, and geometry performance in Tonga. If they grow Tonga to 550mm2 and use HBM instead of GDDR5, 390X could still be just GCN 1.2 but larger with more efficient memory interface. OTOH, they could implement even greater architectural advancements in 390 series. We just don't know but TPU is 100% certain it's GCN 1.3. :D
Headfoot
4,444
641
Yeah, the naming conventions are arbitrary and (understandably) made up by reviewers for convenience. If it's the exact same feature set as Tonga, scaled 2x, with HBM added, is that enough to start calling it GCN 1.3? I think so, just HBM support alone is a very significant revision. Is it enough to start calling it GCN 2.0? I don't know, maybe not. It's most accurate at this time now to refer to the particular product family specifically. This is one of those times generalizing will lead to errors. I'll continue to call it 390x
dn7309
469
I don't mind re branding cards. If the 380x is basically a 290x rebrand then AMD drivers will continue to support the 290X (my current cards). Just make my card last a year or two longer. :hmm:
geoxile
327
25
Source: 3D Center
Well, they kinda do in CodeXL, except it's purely generic and simply listed as "Graphics IPvX". GCN 1.2 is IPv8 IIRC. And on the leaked Carrizo mobile slides from last year they called it GCN generation 3.
boozzer
1,549
18
I believe that the benchmarks, if real, were of the higher end card. It's just that the earlier rumours were conflicting as for the name - some said the top card will be called 380x and some 390x. So, if the benchmarks are real and this rumour is true as well they were describing the 390x.
That said, I wouldn't mind if they described the 380x and 390x will be much higher
Well, one can dream, right?
I want that dream to come true. even if 390x full load is 400 watt, I would buy if it is 70% more performance vs 290x :thumbsup:
3DVagabond
11,951
204
AMD won't be able to win on the internet unless they are ahead perf/W. It's THE spec that is always mentioned by reviewers at the moment. No matter what anyone says positive about it, better performance, better price, you are going to hear, "It uses X million watts = major fail and it proves AMD can't compete.
If it's 50% faster than Hawaii and has a 300W TDP I think that will be terrific. Especially if AMD doesn't add to much of a premium. Although I do know they need the money, they also badly need market share. Let's just hope they make enough of them and we don't see supply/demand inflation and AMD can capitalize on it if it's as good as purported.
boozzer
1,549
18
to be honest, market share is way more important. alot of posters here defend nv because they have no choice, they bought nv :\ going against nv would be like admitting they were wrong.
about reviewers, I am waiting for the reviews this summer for the 3XX series. I wanna see how honest they are or if they are going to pull the same trick this time around also.
RussianSensation
19,458
765
I usually find the types of consumers who argue that Highest sales = best product or Highest market share = best purchase are those who are most misinformed and are least confident in their own purchasing decisions. If you need to buy the most popular products just because they are most popular, it doesn't sound like the type of consumer that can make decisions on his/her own.
If AMD/Intel/NV made the best product at some point in time based on specific needs, I would still buy it even if any of those brands had 5% market share. Conversely, even if a brand has 95% market share, it can still release bad products. A lot of companies have some really great products, good products, average products and some mediocre products. For example, the 970 is a good card but 960 is overpriced and VRAM-gimped. GTX650/650Ti were overpriced and bad buys but GTX670/680 were good products.
stuff_me_good
206
35
+1
It's sad that so many have to swim downstream just like the rest of because can not bother to google a little bit and make own conclusions. Instead just pick whatever everybody else is picking.
I've personally always picked every product based on usage and price. If games that I play run better on brand x than on y, it doesn't matter if all the rest are running better on y.
MrK6
4,458
4
I'm almost expecting to buy a 390X as soon as it comes out. Unless AMD really drops the ball in some metric, it looks like it's going to be a monster.
kawi6rr
567
156
I don't plan on replacing my 290 trix OC anytime soon even if the 390/390x are 2x faster. But I do hope AMD add a better reference cooler and the perf/watt is better so they sell more cards and gain market share, after all competition is good for us consumers.
Creig
13
It won't matter. Whatever metric Nvidia is leading by at the time will suddenly become the most important consideration when purchasing a video card.
RussianSensation
19,458
765
3.5GB for 970 and 970 SLI doesn't matter but I expect 6GB > 4GB to matter greatly for GM200 vs. Fiji.
http://www.fudzilla.com/news/graphics/36995-amd-fiji-hbm-limited-to-4gb-stacked-memory
I am more interested in seeing GM200 OC vs. Fiji OC and 2nd-tier GM200 vs. 2nd tier Fiji. AMD's 2nd tier card tends to be a smoking hot value on the high-end with identical ROPs, memory layout/bus width and VRAM size. However, it's possible this round AMD might charge a big premium for the flagship and outfit that one with AIO CLC but keep the 2nd tier custom AIB air-cooled only. That would be a good strategy to cater to enthusiasts who will pay extra for warrantied Hybrid WC.
Thanks! Love your member name.
AnandThenMan
3,979
589
Being limited to 4GB of memory is a pretty big blunder IMO. If AMD went with stacked memory for one SKU and the rest GDDR5 so they could go to 6 and 8 gig configs then fine, experiment with the new memory but keep the conventional until stacked can go above 4.
You just know Nvidia will market the hell out of 6+ memory cards and review sites will grind AMD to a pulp because of the apparent lack of memory.
DiogoDX
747
279
No matter how fast it will be, 4GB is no go for me. 6GB minimum and 8GB ideal.
RussianSensation
19,458
765
8GB? How long do you keep your videocards for and what's your gaming resolution? 6GB didn't really help the Titan or 780Ti as far as longevity goes.
So if 390X is 10% faster than GM200, costs $200 less you would get GM200 instead for 6GB? I don't know about that. It all depends on a variety of factors, including price, performance, overclocked performance and features.
How many scenarios do you know where games need more than 4GB of VRAM at 1440/1600p?
Since we know that 980 SLI/780TI SLI/295X2 often struggle with games at 4K, a single GM200/390X won't be fast enough for 4K either. That leaves us with a tiny fraction of users who have 3440x1440/4K or multi-monitor setups and are getting at least 2 of such cards. Do you think those are the types of gamers who will hang on to these flagship cards when 14nm GPUs arrive? Those are cutting edge gamers who will upgrade every 2 years, if not sooner.
I am really hoping the 2nd tier R9 300 card is very close in performance once OC. Historically that has been the case with 5850 vs. 5870, 6950 vs. 6970, 7950 vs. 7970, and 290 vs. 290X.
Paul98
3,732
199
Yeah I would have liked to see 6gb of vram also. But I guess we will have to wait to see how things pan out.
