vbscript problems
NiKeFiDO
3,901
Well in my web design class the teacher is using vbscript. its fairly simple, but I am having a huge problem.
I basically have a bunch of text boxes I am using and I need to do conversions across them (miles to kilometeres etc)
Im having trouble the the "if else" statements
What I need to do is be able to convert back and forth between miles and kilometers etc. so if they input km they get miles and visa-versa.
Here it is so far, workes best in ms visual studio since thats is what im forced to use.
any ideas on why when I add the 2nd if statement the program just stops working?
http://www.fidaofamily.com/Chris/9906hw1.htm
(right click, save target as, open in compiler)
KB
5,406
389
vbscript does not like the = empty comparison
vbscript also wants different variable names in each area of the IF clause:
If statement should look like
IF ... THEN
ELSEIF ... THEN
END IF
NiKeFiDO
3,901
the other option is did was
if isnumeric(window.miles.value)=true
could i just use that instead?
also, ill work on the structure of the if-then
oh, and the diff variable names is clutch knowledge to know, thanks...
imported_Phil
9,837
IF ... THEN
ELSEIF ... THEN
END IF
Agreed. Not knowing VBS makes it difficult for me, but with a knowledge of C++ I can see where he's going wrong. What you posted is pretty much what I posted in his TFNN thread.
NiKeFiDO
3,901
Phil i had the if else stuff OK (eventually lol), just got it to work, the only problem was the variable naming part (see above 🙂 )
thanks a lot guys! - will let you know if anything else crops up.
imported_Phil
9,837
You had it just like this?
'if isnumeric(window.kilometers.value)=true then
elseif window.miles.value=empty then
dim mile, kilometer
kilometer=csng (window.kilometers.value)
mile=kilometer/1.609347
window.miles.value=mile
end if
I really can't see how that would work. The logic behind that if() statement is mind-boggling 😛
NiKeFiDO
3,901
no not at all like that, i still dont know why you have
where did that "elseif" come from?
NiKeFiDO
3,901
'Pounds and kilogram conversion
if isnumeric(window.pounds.value)=true then
dim pound, kilogram
pound=csng (window.pounds.value)
kilogram=pound*.4536
window.kilograms.value=kilogram
elseif isnumeric(window.kilograms.value)=true then
dim pound1, kilogram1
kilogram1=csng (window.kilograms.value)
pound1=kilogram1 / .4536
window.pounds.value=pound1
end if
NiKeFiDO
3,901
http://www.fidaofamily.com/Chris/9906hw1.htm <--updated to up to now
last problem I am having (probably simple)
everything works up until the last conversion! the last converstion is fahrenheit to celsius..
here is the code:
'Fahrenheit and celsius conversion
if isnumeric (window.fahrenheit.value)=true then
dim fahr, cels
fahr=csng (window.fahrenheit.value)
cels = (fahr ? 32)/1.8
window.celsius.value=cels
elseif isnumeric(window.celsius.value)=true then
dim fahr1, cels1
cels1=csng (window.celsius.value)
fahr1 = (1.8*cels1) + 32
window.fahrenheit.value=fahr1
end if
see anything wrong with this? seems the same as the others to me, but this part wont work! Again, check out the updated version 🙂
also, my reset button doesnt work. wtf?
NiKeFiDO
3,901
not sure what the diff is, but I got it to work by retyping the whole last statement
if isnumeric (window.faren.value)=true then
dim degFaren, degCels
degFaren=csng(window.faren.value)
degCels=((degFaren-32)/1.8)
window.cels.value=degCels
elseif isnumeric (window.cels.value)=true then
dim degFaren1, degCels1
degCels1=csng(window.cels.value)
degFaren1=((1.8*degCels1)+32)
window.faren.value=degFaren1
end if
imported_Phil
9,837
From your source code, you gigantic halfwit 😛 😉
SaturnX
3,415
end if
I'm not sure how VBScript works, as I've never used it, but if it functions the same way as VB does, by doing a dim statement WITHOUT the AS [VariableType] declaration ends up allocating them as Variants. Which given that they're numbers is a huge waste a space, (yes I know this is a simple app and it wouldnt' be relavent, but still good programming practice)
Then again I'm not sure if you can do that...
--Mark
kamper
5,513
Sorry for the giant threadcrap I'm about to take but ...
Why are you learning vbscript in a web design class? Does your instructor not understand that there is more than one browser in the world and that standards matter?
Rip the Jacker
5,415
/me dies reading the code
<-- Programming Newbie, but like kamper said, why are you learning VBScript in a web design class? I don't think it's ever used.
XHTML --> CSS --> Javascript --> PHP
