Question VBS Scripting - Help Needed
BadThad
12,100
49
I need a VBS script to kill two running processes. I can do it in PowerShell, no problems using:
taskkill /f /im CorsTra.exe
taskkill /f /im M95Hid.exe
However, in my google searches (yes, I'm pathetic with code) none of the suggestions worked and I tried a few like this:
Dim oShell : Set oShell = CreateObject("WScript.Shell")​
oShell.Run "taskkill /f /im M95Hid.exe",,True​
oShell.Run "taskkill /f /im CorsTra.exe",,True​
What VBS code do I need to accomplish this simple task because the above and nothing else I tried does? They run but the processes never end. Thanks!
Reactions: Orfosaurio
lantis3
279
56
61
Why not just remove them from startup?
Reactions: quietdad2
BadThad
12,100
49
Because I want them to run at start-up and my PC very rarely gets rebooted. There are reasons I need to do this, I've been a computer enthusiast for 25+ years.
lantis3
279
56
61
or
or
BadThad
12,100
49
Why not just create a powershell script?
That is exactly what I'm trying to do. However, it does not stop the processes - I just want help with the syntax I posted above. As stated, I can open powershell and the commands execute successfully with no problems (the processes stop). However, when I write the code, save it as a .vbs file and run it - it does not stop the processes.
Thanks
Ajay
16,094
8,112
Thanks
Sorry, I misunderstood. You want code that'll do what PowerShell does easily, except as a VB script. Good luck, haven't written any VBS in long time.
Reactions: BadThad
BadThad
12,100
49
Exactly, thanks for clearing it up. It's a simple thing really, a lot of people know VB....but they're not here anymore I guess. :(
lantis3
279
56
61
What errors are you getting?
When I copy & paste your code into notepad++, it kept complaining invalid characters
When I turned on showing all hidden characters, it showed that ZWSP (zero width space) character was appended at the end of line. I have to remove that ZWSP from the file so it can compile.
The following code worked without error.
Code:
Dim oShell
Set oShell = Wscript.CreateObject("WScript.Shell")
oShell.Run "taskkill /f /im notepad.exe"
Set oShell = Nothing
Also haven't done programming for a long time, by the way.
Can't install Corsair M95 software since I don't have that mouse.
TheELF
4,027
753
Thanks
You do not need to run this as VBS, save it as a text file rename the extension to .bat and run it as administrator, or just run the vbs as admin, I'm pretty sure the only issue here is the admin/elevated access.
You can only run powershell as admin so it would work inside of that, outside you have to force admin.
I'm talking about these commands.
BadThad
12,100
49
YES - that worked! Hallelujah, you are THE MAN, thanks!
