- Nov 15, 2010
- 8,115
- 0
- 71
:thumbsup:
http://www.techpowerup.com/forums/showthread.php?t=189089
Also no MVDDC, which isn't a huge deal but I'd like to see it added.
That said with the fan profile, custom wattage for powertune and core/memory clocks with VDDC adjustment this is the cats meow as far as I'm concerned.
Thought I'd share since I've been looking for something like this since, forever.
Doesn't work with UEFI/GOP, but I can live with that (maybe I'll try sending in a custom bios to MSI and see if they'll GOP it for me).With this tool you will be able to
- Change Vendor ID / Subsystem ID (not recommended)
- Change clocks and voltages
- Change OverDrive's core clock and memory clock limits, TDP limit, power limit
- Make custom fan profile
There are some limitations though...
- You cant change 2D / UVD voltages
- You cant set 2D / UVD clocks higher than the values stored in BIOS (these limitations are intentional, without these limits powerplay would go nuts...)
- The following voltage regulators are fully supported: CHL822x, CHL8214, UP1637, UP1801, ST6788A, VT1556M
- For unknown voltage regulators, you can select voltage from a predefined table.
