Hi, everyone. This is my first topic on this forum. I recently build a system for
myself (CPU, MB, RAM, Video card... detail in my signature). I OC my
Sempron 3000+ from 1.6G to 2.4G . The system can pass memory test without
error. The CPU's temp. is ranged from 31(idle) to 46(100% utilize).
I installed the MB's (BioStar tForce 6100AM2) bundle software which monitors'
fan speed, CPU's temp and voltage, chip's temp, CMOS battery's voltage (VBAT)
. It keeps posting error on VBAT (overflow/underflow) as the CPU's running at
full speed. Also, a couple of errors on CPU's fan (can't sync.).
Does the VBAT problem matter? How can I sort the problem?
On the 2nd thought, I doubt the bundle software is setting fraud altert. I'll
appreciate any comment. Thanks.
[My OC set up]
***CPU part***
set FSB to 300, multiplier to 3, raise CPU's voltage
from 1.35 to 1.45v
***Memory part***
set DRAM voltage from 1.85v to 1.90v (1.85v is the MB's min, the RAM module is default 1.80 v).
set DRAM frequency to DDR 400 (option: 400/533/667/800/Auto)
set DRAM latency 4-4-4-12
[My OC set up]
***CPU part***
from 1.35 to 1.45v
***Memory part***
