VB .res and .rc problem
leezard
1. open your project folder (i.e. "C:\Windows\Desktop\FlashTutorial")
2. right-click on the window, and click on "New|Text Document"
3. rename the newly-created file to "tutorial.rc" (please note that the
file HAS TO END WITH AN "RC" extension, or this may not work).
4. double-click on the new text file, and add this line:
555 SWF tutorial.swf
5. click on "Start|Run...", and locate the "RC.EXE" file on your hard
disk. after that, type the following at the end of the "Run" dialog:
-r "[FLASHTUTORIAL_FOLDER]\tutorial.swf"
... where "[FLASHTUTORIAL_FOLDER]" stands for the path of the
"tutorial.swf" file.
This should make the end text to be something *similar* to the
following:
"[RESOURCE_COMPILER_FOLDER]\RC.EXE" -r "[FLASHTUTORIAL_FOLDER]\tutorial.swf"
...where "[RESOURCE_COMPILER_FOLDER]" stands for the path of the
"RC.EXE" program.
6. click on "OK" to start the compilation. if everything was done
correctly, a new RES file, named "tutorial.res", will be created on the
same path as your "tutorial.rc" file.
my question is........when i click "OK" there is no compilation and the "tutorial.res" was not created
Anybody can help me? (thanks in advance)
