I need to "copy" the a few controls (a couple of radio buttons, label, etc.) into a frame. And if I just copy and paste into the frame, it just goes over top of the frame and not "in" it.
poontos,
i think you might be dragging your controls onto the frame. try cutting and pasting it on top of the frame or create them directly in the frame.
