This should be an easy one for someone that has done some VB before. I have really never used it VB since I use C++ and Java.
I have a method called:
HRESULT Initialize()
params: none
return: S_OK - success
F_FAIL - Failure
This method opens a connection to a message display (i already have the message display control installed and added to the project)
This project is in Excel. What i am trying to do is open the connection to the display, and then determine if it was a success or a failure. I would like to update a cell in the spreadsheet with a 0 or a 1 according to what the return value is. Here is what i have:
Private Sub CommandButton1_Click()
InViewCtrl1.Initialize ' Opens coms to the display
If Initialize = E_FAIL Then
Sheet1.Cells(1, 1) = 0
End If
If Initialize = S_OK Then
Sheet1.Cells(1, 1) = 1
End If
InViewCtrl1.AddMessage (1) 'Adds message #1 to the displays queue
InViewCtrl1.Close 'Closes coms to the display
End Sub
The problem i have is weather or not the connection was successful it always displays a 1. (I have forced connection failures by unplugging the display)
Any ideas?
Thanks,
Matt
params: none
F_FAIL - Failure
End If
End If
End Sub
Any ideas?
Thanks,
Matt
