To all the anand programming wizards. I do not know VB code but is in need of help on data filtering/matching. I have 2 very big excel workbooks with a few thousand lines and am trying to do some filtering/matching. Example below.
The two workbooks I have contains same data in column A and also column D from the first data set is the same as column B in the 2nd data set. I am trying to add column C and D from the 2nd data set to the 1st data set and need to make sure they match up to column D from 1st set and B from 2nd set. It is quite strenuous to do this manually, any input would be greatly appreciated.
Thanks!
A1 2 3 100A
A1 2 3 100B
A1 2 3 100C
A1 2 3 100D
A1 100A AA BA
A1 100B AB BB
A1 100C AC BC
A1 100D AD BD
Thanks!
A1 2 3 100A
A1 2 3 100B
A1 2 3 100C
A1 2 3 100D
A1 100A AA BA
A1 100B AB BB
A1 100C AC BC
A1 100D AD BD
