VB 6 HELP! I need to put a check box on a grid, but the box stays behind the grid!
shaolin9
169
HELP!
I have a Sheridan grid I am using, but for some reason when I put a Checkbox on the "Caption" part of the grid it ends up being behind it.
I have already tried the "Send to Back" command for the grid and the Send to Front command for the Checkbox..it didnt work..
I also made sure the visible was on for the checkbox...which is working, but the problem is that it always ends up BEHIND the grid...
Is there anyone out there that knows a solution for this quirk?? The weird thing is that it worked fine for a previous project, but not on this one...Anyhow any advice would be appreciated :)
TIA
