Originally posted by: alexXx
yes, im using 'Flecto, varathane elite'
I've been told just the opposite. Gloss as undercoats, satins as top coats.Originally posted by: shot
is that the water based finish? if so its not really a varnish, more of an acrylic finish. Or is it the diamond IPN finish? The later is some excellent finish.
If you going for a high gloss finish, the first 2 coats should be a satin finish then use whatever finish you want. This will also bring out the depth of the wood grain.
Satins have solids suspended in them, multiple coats of satins can give a milky appearance.
