- Mar 31, 2003
- 11,679
- 0
- 81
I have had these problems before in Ubuntu, I just don't know how to fix them. Since my Tablet PC dedicated for school work is now using 7.10 exclusively I need to make sure everything works.
First off, when prompted I installed Adobe Flash player. This did nothing-- NOTHING (Despite saying that it was installed). So when prompted again, I installed the GNASH plugin-- while this works, the quality is bad and all the buttons and whatnot (Google Video for instance) are piled one on top of another. Did I do something wrong here?
Next, I have various .m4a and .wma files. Without going to VLC for all media purposes, what do I need to download for all of these to work? (Also is there any program out there that is similar to the latest versions of Winamp?)
Also, I want to download Eclipse and Netbeans. I found them in the repositories; however, I want to know what else I have to download to get Java code to run and compile properly.
Thanks So Much,
-Kevin
Thanks So Much,
-Kevin
