This will be for an AMD XP 2200 that will not or ever be overclocked.
Overclockers.com rates the VANTEC AEROFLOW VA4-C7040 at a .30C/W and it can be purchased for around $22
Overclockers.com rates the Speeze 5R265B1H3 at .33C/W and this can be purchased for around $13.
I cannot seem to find any data on the apparently newer Speeze 5T321B1 that is also around $13.
My possible 3rd choice would be the Volcano 9, but I do not know yet if it will fit on the motherboard.
My original Alpha 8045 (on another system now) would not fit without a mod.
For comparison the Alpha 8045 was rated at .34C/W at overclockers.com.
Lower levels of noise is needed. These are about the loudest fans that can be used.
I considered other, more powerful coolers, but the rated noise level was too high.
Your input is appreciated,
Mark
Mark
