- Jun 13, 2004
- 118
- 0
- 0
I dropped a Vantec in in the second slot from my BFG 6800gt, temps on the video card dropped a bit, but nothing major. So I took the blank plate off the 3rd pci slot on the case ( directly below the Vantec ). It didn't do much more to lower my video card anymore, but now the entire case now runs cooler. Definately sucks cool air in from the back now.
Case is a Praetorian with 2 80mm up front, one in the top, and one in the back. I replaced the 4 stock fans with some 36 cfm Sunon fans for a little more push.
I love the case, only issue I have is the metal screens on the case don't allow for max airflow.They originally came with filters as well. They came out the first day.
I had an Acer full tower before and I liked the way the front edge on the bottom of the case was notched to allow air to be sucked in from under the front cover. It worked well so I took the dremmel and etched a 3 inch by 1/2 inch notch in the bottom front of my Praetorian. You can't see the cut once the front cover is on, but airflow thru my front fans has increased quite a bit.
After these 2 simple mods my case temp has dropped by a good 5 degrees, which seems to aid in cooling my SLK-948u that much more.
Iron
Iron
