Hello,
I'm thinking about buying a Vantec NexStar 6G 3.5'' (NST-366S3) USB3.0 hard drive enclosure.
I want to use it with a 4TB hard drive.
This enclosure should support drives up to 6TB.
Does this NexStar 6G support formatting of a 4TB hard drive with GPT mode, and creating a single 4TB partition?
I'm asking because I've read about USB hard drive enclosures which don't permit to create a single partition which is larger than 2TB. For example a 3TB hard drive had to be used with a 2TB partition, and the remaining space was another partition.
If I understood correctly!
I don't want to have two 2TB partitions with a 4TB hard drive, I want one partition which uses the full disk space.
Also, I read the following on the Anandtech forums, and would like to know if the problem could occur also with the Vantec NexStar 6G:
"Some USB docks/adapters don't properly recognize the sector size of newer drives (2Tb+) and won't partition/format it properly.
It might seem to work at first, but when you move it over to SATA (which will recognize the sector size correctly) it's all messed up."
Thanks.
Thanks.
