Value Disc 50pk 80min CDR's, 32x max write - $1.99 after rebates $8.99 after instant
JugStafe
Came across their webpage and found this link for their cdrz. I don't know if anyone has listed it yet but here it is. Seems like a really good deal to me, I usually try to find this cheapest non-silvertop 50pk 80 min cdrz that I can. Anyways, here is the link...
http://www.officemax.com/max/solutions/product/prodBlock.jsp?BV_UseBVCookie=yes&expansionOID=-536891921&prodBlockOID=536956913
Somebody post more info if you have it, whether these in fact are silvertop cdrz or how much shipping is, and if they have these at local stores. I just came across link will probably order some later on.
These are available in stores and online. They are Khypermedias and read as CMC Magnetics. Ive still got 100 left over from the a few weeks ago when they did the similar deal. At the time tho they had 50 for 9.99$ so this is even better.
The link doesnt work, but it doesnt matter, the deal was on the page that it went to after the message about session timing out. Thanks, I might order some of these.
Shipping to TN was going to run about $5 for 1 of them. My buddy was going to order, but that seemed a bit steep since we have a couple in the area. It wont give you the shipping until just before you click ok for the entire order...after signing up and all that.
If these are Khypermedia 32x, they suck. I bought some thinking they would be the same quality as the outpost deal a year or so back. Not so. They write fine, but have problems reading. YMMV.
cdrid
ATIP: 97m 26s 66f
Disc Manufacturer: CMC Magnetics Corp.
Reflective layer: Dye (Short strategy; e.g. Phtalocyanine)
Media type: CD-Recordable
Recording Speeds: min. unknown - max. unknown
nominal Capacity: 702.83MB (79m 59s 74f / LBA: 359849)
Paul
I bought these at my local OM and they didn't have the black wrapper, but the red one that says Khypermedia 32x. Anyway.. I looked at the rebate and it gave a specific UPC code that was different from the one on the package. Would you risk sending in the rebate? I talked to someone at OM and they said it would be fine, but what do they know?
Let me know what you think?
Sal
<< I bought these at my local OM and they didn't have the black wrapper, but the red one that says Khypermedia 32x. Anyway.. I looked at the rebate and it gave a specific UPC code that was different from the one on the package. Would you risk sending in the rebate? I talked to someone at OM and they said it would be fine, but what do they know?
Sal
i got the same thing.. its supposed to be green ones and the last number on sku is different..
what do u mean by risk?
they are burning fine at 24x tho (burned 5 so far).
its only $10, ill send in the rebate but most likely wont get it .
also if you read the rebates, it specifically asks for a rebate receipt on top of the normal receipt.
i didnt get such thing,, oh well...
its only $10.
I suppose these CD-Rs are cheap for a reason -- they don't even have a protective layer on top! I don't think I have ever used this kind of discs before. Do I need to put labels on them? Can these be damaged if the top surface gets scratched slightly?
I got these and promptly burned 3 bad disks out of the first 5. Never have I had media this bad before. Burner 4 more disks fine after that, with some TDK media I had. I returned these crap disks even though I sent in the rebate, I told them and they still gave me a full refund. They wanted all the disks back, but still were very nice about the whole deal as I though there would be problems with the rebate already being sent in. I DO NOT RECOMEND these as they are VERY poor quality.
