Vacuum Brake Bleeder
Status
Not open for further replies.
thescreensavers
9,916
Which bleeder do you guys recommend for ~$100. There seems to be many options I just dont know whats crap and whats good.
Meghan54
11,684
5,225
Or you can save a bunch of $$ by buying a friend a beer or two and bleed your brakes the old fashioned way. Cost is under $10.
Railgun
1,289
Only if you do a lot of bleeds alone do you need a pressure bleeder, and I`d prefer one over a vac anyday. Obviously, as above, a friend is the cheapest route, but a pressure bleeder makes it an extremely easy job.
T2urtle
3,432
Motive pressure bleeders run about $60. Only problem I read is the cap for theb master might not always seal, but i think that is only for the universal caps.
I don't have one myself, I normally two man method it. I have a vac pump but doesn't work as well. That was a $35 investment. Pressure is the way to go. Dealerships use it.
TapaTalking
Sep 7, 2009
12,960
I've heard a few people swear up and down that these vacuum bleeders do a better job of getting the small bubbles compared to the pressure bleeders or doing it with an assistant...
JCH13
4,981
66
Vacuum bleeders make the air bubbles bigger, which makes them easier to draw out of hard-to-reach places. Just have to be careful there are no leaks which can draw air in. I really like my vacuum bleeder, FWIW.
Dec 30, 2004
12,553
the one from harbor freight sucks don't buy it. Supposed to bolt on with your air compressor, yeah, no dice.
Bartman39
Elite Member | For Sale/Trade
Jul 4, 2000
8,867
51
Gravity has always been my friend and is not all that expensive...:thumbsup:
But if you want to get high tech just get 2-3ft. of vac hose and a clear plastic bottle (20 oz water bottle works great) and large bottle of brake fluid... Fill the coke bottle (clean and dry it duh...) about 1/2 full of brake fluid then use the vac hose to slip on the brake bleeder and place the other end in the bottle with brake fluid and open the bleed screw about 1/2 turn... Then press down slowly (the slower the better) on the brake pedal and repeat 2-3 times then close off the bleed screw... Be sure to keep the master cylinder full and start with bleeding the wheel that is the most far away from the master cylinder and work your way to the drivers side front...
A one person or do it yourself very reliable system...;)
thescreensavers
9,916
Thanks for the replies, I have done the buddy system but It does not really get all the fluid out, and its slow heh.
My friends truck had stuff that looked like motor oil, we did the buddy system and two 32oz bottles later and it still wasn't new looking.
So that's why I thought about the pressure bleeders, I was looking at motive bleeders they look decent
NutBucket
27,124
613
Motive is definitely the way to go. Makes brake bleeding a pleasure instead of a chore. Much prefer it to the vacuum method.
Howard
47,982
10
When you raise the pedal doesn't it suck back? How do you make sure it pulls clean fluid only?
Status
