uTorrent problems
Tullphan
3,507
I've not been having any problems at all lately with uTorrent, then the other day I went to download a file. It downloaded for a couple of minutes, then stopped & gave me an I/O Device Error. I restarted the file, but got the same message. I tried a totally different file...same thing.
I googled "uTorrent I/O device error" & got some hits. I checked them out & they pretty much said hardware problems. I then changed to where I had my files downloaded to my main drive, started downloading another file & got the same message.
I'm currently running Spinrite to see if I may have bad sectors, but i'm curious as to whether anyone else has had this problem & what their issue was so I won't have to wait another 38 hours for Spinrite to get done. :)
Thanks
Tullphan
3,507
Originally posted by: Nothinman
Well did you look now?
[2009-03-03 18:24:51] Loaded ipfilter.dat (284468 entries)
[2009-03-03 18:24:51] IPv6 is installed
[2009-03-03 18:28:09] IO Error:1117 line:459 align:512 pos:544742400 count:524800 actual:-99
[2009-03-03 18:28:09] IO Error:1117 line:685 align:512 pos:544742729 count:524288 actual:1
[2009-03-03 18:28:19] IO Error:1117 line:459 align:512 pos:125828096 count:33280 actual:-99
[2009-03-03 18:28:19] IO Error:1117 line:685 align:512 pos:125828425 count:32768 actual:1
[2009-03-03 18:28:27] IO Error:1117 line:459 align:512 pos:125893632 count:33280 actual:-99
[2009-03-03 18:28:27] IO Error:1117 line:685 align:512 pos:125893961 count:32768 actual:1
[2009-03-03 18:28:35] IO Error:1117 line:459 align:512 pos:125959168 count:16896 actual:-99
[2009-03-03 18:28:35] IO Error:1117 line:685 align:512 pos:125959497 count:16384 actual:1
[2009-03-03 18:28:43] IO Error:1117 line:459 align:512 pos:126073856 count:16896 actual:-99
[2009-03-03 18:28:43] IO Error:1117 line:685 align:512 pos:126074185 count:16384 actual:1
[2009-03-03 18:28:51] IO Error:1117 line:459 align:512 pos:126106624 count:16896 actual:-99
[2009-03-03 18:28:51] IO Error:1117 line:685 align:512 pos:126106953 count:16384 actual:1
Nothinman
30,672
In the system eventlog it should say something like "An error was detected on device \Device\Harddisk0\D during a paging operation."
Tullphan
3,507
The only error I found (a few similar, actually) was from source "WMI" that stated Log Name: Application
Source: Microsoft-Windows-WMI
Date: 2/21/2009 12:31:57 AM
Event ID: 10
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: xxxxxx
Description:
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-WMI" Guid="{1edeee53-0afe-4609-b846-d8c0b2075b1f}" EventSourceName="WinMgmt" />
<EventID Qualifiers="49152">10</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2009-02-21T06:31:57.000Z" />
<EventRecordID>4946</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>xxxxx</Computer>
<Security />
</System>
<EventData>
<Data>//./root/CIMV2</Data>
<Data>SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99</Data>
<Data>0x80041003</Data>
</EventData>
</Event>
I was looking under the "applications" subcategory of "windows logs".
*Edit*
I also found the following from this morning...after I tried (unsuccessfully) to download using BitComet (although I was successful for the first torrent, but not the 2nd or 3rd). I then ran CHKDSK afterwards, but can find the log.
Source: Microsoft-Windows-User Profiles Service
Date: 3/4/2009 5:34:59 AM
Event ID: 1530
Task Category: None
Level: Warning
Keywords: Classic
User: SYSTEM
Computer: xxxxx
Description:
Windows detected your registry file is still in use by other applications or services. The file will be unloaded now. The applications or services that hold your registry file may not function properly afterwards.
DETAIL -
2 user registry handles leaked from \Registry\User\S-1-5-21-3961069183-280791790-936434097-1000_Classes:
Process 1004 (\Device\HarddiskVolume1\Windows\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3961069183-280791790-936434097-1000_CLASSES
Process 1396 (\Device\HarddiskVolume1\Windows\System32\spoolsv.exe) has opened key \REGISTRY\USER\S-1-5-21-3961069183-280791790-936434097-1000_CLASSES\Local Settings\Software\Microsoft\Windows\Shell\MuiCache
Event Xml:
<System>
<Provider Name="Microsoft-Windows-User Profiles Service" Guid="{89B1E9F0-5AFF-44A6-9B44-0A07A7CE5845}" EventSourceName="profsvc" />
<EventID Qualifiers="32768">1530</EventID>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2009-03-04T11:34:59.000Z" />
<EventRecordID>5335</EventRecordID>
<Correlation />
<Security UserID="S-1-5-18" />
</System>
<EventData Name="EVENT_HIVE_LEAK">
<Data Name="Detail">2 user registry handles leaked from \Registry\User\S-1-5-21-3961069183-280791790-936434097-1000_Classes:
</Data>
</EventData>
</Event>
Tullphan
3,507
Still having this problem after upgrading to the newest uTorrent.
I was able to download another file, but got the error again when it was 99.7% done. I kept restarting the torrent & it finally finished.
I defrag my drives weekly, so fragmentation isn't an issue.
I ran Western Digital's drive utility on the drives & it found no problems.
I set it to override automatic cache size & manually set it to 2048mb (half my ram) after getting disk overload error.
Are there any other settings I may be overlooking that I need to change?
CuriousMike
3,044
544
You might try booting in Safe Mode and trying a download... if you can download successfully in safe mode, then it's likely a software issue and not hardware.
Tullphan
3,507
I booted into safe mode, started uTorrent & tried to resume the download i've been getting error messages with.
I still got the same error message.
Tullphan
3,507
I noticed I had a s**t-load of the following errors when I went back to the event log:
Event11,atapi
The driver detected a controller error on \Device\Ide\IdePort3
What exactly does that mean? Bad motherboard? CPU? The drives tested fine as did the memory.
Tullphan
3,507
Good question!
I have no IDE devices, only SATA.
*Edit*
I checked my motherboard's user manual & the device that's plugged into SATA3 is one of my optical drives.
Tullphan
3,507
I'm running Vista, if that matters & I have no SCSI devices.
I checked out that site, but cannot determine anything about checking the Model Number and Firmware Revision of my SATA drives...or is it possible?
Is there an issue with the WD6400AAKS's?
Nothinman
30,672
The actual type of device doesn't matter much, ATAPI is essentially SCSI over ATA.
As for the real problem, it's hard to say. Do you have another controller that you could move your disks to? I don't know how easy that will be since you're running Windows though.
Tullphan
3,507
My drives are plugged into the SATA ports on the motherboard.
I did start another torrent...2 actually...and had them to download onto my "C" drive instead of my "D" drive. So far one's completed & the other's 90% done.
I'll run another WD test on my "D" drive, but if it doesn't turn up any errors, how could I RMA it? Or should I try plugging it into another SATA port?
