Utility for measuring power supply usage...
jtelep
39
Does anyone know if there are any good utilities for measuring how much juice you PS is putting out at a given time and what kind of condition the power is? I have been looking around but so far have been unable to find anything.
Thanks.
StevenYoo
8,628
there's a product called the kill-a-watt, which measures wattage of items plugged into a particular outlet
jtelep
39
Ya but I mean something that actually resides within windows. What I am looking for is a utility that will actually monitor the usage of the PS so I know whether or not I am using too much and will also let me know if the quality of the power coming from the PS is bad.
Is there anything out there like that?
PottedMeat
12,363
475
Maybe theres a UPS that does monitoring like that, but a computer based one? I dont think so, it would have to do current monitoring as well as voltage monitoring to tell you the power usage. Most do voltage monitoring ( usually inaccurately ), none do current as far as I know.
Zepper
18,998
Something like the KillAWatt is it for home use. You'd have to build the same thing with A to D conversion to be machine readable - not worth the cost when the KaW is less than $20..
.bh.
