eggrolls
Well, the problem is this: I double-click the .exe or shortcut, splash screen appears and disappears after several seconds, then nothing. Not even an error message. There are no logs in the game's folder
While the splash screen is there, the hard drive is loading stuff and there's noticeable CPU usage from the .exe according to task manager. Afterwards, the process is gone and nothing else happens.
Things I've tried:
- restarting
- uninstalling/reinstalling
- installing in default folder
- downloading installer from other mirrors
Not sure what else to do. My specs are Q6600, 2GB, 7600GT, XP Home SP2, with latest drivers. My other games work fine.
Any ideas?
edit: there's actually a log, but I don't see any errors other than the fact it's cut off at the end
Things I've tried:
- restarting
Any ideas?
Log: Log file open, 10/19/07 01:26:11
Init: Version: 3464
Init: Epic Internal: 0
Init: Compiled: Oct 11 2007 19:21:48
Init: Command line:
Init: Base directory: D:\Unreal Tournament 3 Demo\Binaries\
Init: Character set: Unicode
Log: GConfig::LoadFile has loaded file: ..\UTGame\Config\UTEditor.ini
Log: GConfig::LoadFile has loaded file: ..\UTGame\Config\UTEditorUserSettings.ini
Log: GConfig::LoadFile has loaded file: ..\UTGame\Config\UTDemoCompat.ini
Log: GConfig::LoadFile has loaded file: ..\UTGame\Config\UTEngine.ini
Log: GConfig::LoadFile has loaded file: ..\UTGame\Config\UTGame.ini
Log: GConfig::LoadFile has loaded file: ..\UTGame\Config\UTInput.ini
Log: GConfig::LoadFile has loaded file: ..\UTGame\Config\UTUI.ini
Init: CPU Page size=4096, Processors=4
Init: High frequency timer resolution =2400.080000 MHz
Init: Memory total: Phys=2095596K Pagef=1938340K Virt=2097024K
Init: WinSock: version 1.1 (2.2), MaxSocks=32767, MaxUdp=65467
Init: Presizing for 83221 objects not considered by GC, pre-allocating 0 bytes.
Init: WinSock: I am moses-c53480201 (169.229.96.212:0)
Init: Object subsystem initialized
Log: DEMOVERSION is defined.
Init: Startup System Settings:
Init: System Settings:
Init: StaticDecals=true
Init: DynamicDecals=true
Init: DynamicLights=true
Init: DynamicShadows=false
Init: LightEnvironmentShadows=true
Init: CompositeDynamicLights=true
Init: DirectionalLightmaps=true
Init: MotionBlur=false
Init: DepthOfField=true
Init: Bloom=true
Init: QualityBloom=false
Init: Distortion=true
Init: DropParticleDistortion=true
Init: SpeedTreeLeaves=true
Init: SpeedTreeFronds=true
Init: OnlyStreamInTextures=false
Init: LensFlares=true
Init: FogVolumes=true
Init: FloatingPointRenderTargets=true
Init: Trilinear=false
Init: OneFrameThreadLag=true
Init: UseVsync=false
Init: UpscaleScreenPercentage=true
Init: Fullscreen=true
Init: AllowD3D10=true
Init: EnableHighPolyChars=false
Init: SkeletalMeshLODBias=0
Init: ParticleLODBias=1
Init: DetailMode=1
Init: ShadowFilterQualityBias=0
Init: MaxAnisotropy=4
Init: MaxMultisamples=1
Init: MinShadowResolution=32
Init: MaxShadowResolution=512
Init: ResX=800
Init: ResY=600
Init: ScreenPercentage=100.000
Init: SceneCaptureStreamingMultiplier=1.000
Init: FoliageDrawRadiusMultiplier=0.500
Init: ShadowTexelsPerPixel=2.000
Log: TEXTUREGROUP_World: (MinLODSize= 256,MaxLODSize=1024,LODBias=1)
Log: TEXTUREGROUP_WorldNormalMap: (MinLODSize= 256,MaxLODSize=1024,LODBias=2)
Log: TEXTUREGROUP_WorldSpecular: (MinLODSize= 256,MaxLODSize=1024,LODBias=1)
Log: TEXTUREGROUP_Character: (MinLODSize= 256,MaxLODSize=1024,LODBias=1)
Log: TEXTUREGROUP_CharacterNormalMap: (MinLODSize= 256,MaxLODSize=1024,LODBias=1)
Log: TEXTUREGROUP_CharacterSpecular: (MinLODSize= 256,MaxLODSize=1024,LODBias=1)
Log: TEXTUREGROUP_Weapon: (MinLODSize= 256,MaxLODSize=1024,LODBias=1)
Log: TEXTUREGROUP_WeaponNormalMap: (MinLODSize= 256,MaxLODSize=1024,LODBias=2)
Log: TEXTUREGROUP_WeaponSpecular: (MinLODSize= 256,MaxLODSize=1024,LODBias=1)
Log: TEXTUREGROUP_Vehicle: (MinLODSize= 512,MaxLODSize=2048,LODBias=1)
Log: TEXTUREGROUP_VehicleNormalMap: (MinLODSize= 512,MaxLODSize=2048,LODBias=1)
Log: TEXTUREGROUP_VehicleSpecular: (MinLODSize= 512,MaxLODSize=2048,LODBias=1)
Log: TEXTUREGROUP_Effects: (MinLODSize= 256,MaxLODSize=1024,LODBias=1)
Log: TEXTUREGROUP_Skybox: (MinLODSize= 512,MaxLODSize=2048,LODBias=0)
Log: TEXTUREGROUP_UI: (MinLODSize=1024,MaxLODSize=4096,LODBias=0)
Log: TEXTUREGROUP_LightAndShadowMap: (MinLODSize= 512,MaxLODSize=4096,LODBias=0)
Log: TEXTUREGROUP_RenderTarget: (MinLODSize= 1,MaxLODSize=4096,LODBias=0)
Init: Friendly System Settings:
Init: TextureDetail=Level3
Init: WorldDetail=Level3
Init: bUseVSync=0
Init: bUseMSAA=0
Init: UpscaleScreenPercentage=1
Init: ResX= 800
Init: ResY= 600
Init: Fullscreen=1
Init: OS stats:
Init: Windows XP Service Pack 2
Init: RemoteDesktop=0
Init: Memor</end quote></div
