UT2004 benchmarking, please help!
JungleMan1
I can't benchmark UT2004. I installed the game, installed UMark 1.2, no matter what map I try to run, it doesn't move the camera around a pre-set path...so I have to move it around myself, which makes the benchmark invalid...
Please, someone tell me, how do you benchmark this game??? Thanks..
Sorry not sure about that, but you can at least do a manual comparison with "stat fps" at the console.
I have the exact same problem. Do you have the DVD SE version of the game? I do and in the initial install I don't even have the benchmark.exe program. It's only after I install the latest patch that I even get the exe file. I think the DVD SE version is missing some files to do a proper benchmark. If someone could zip up there benchmark folder in the game and send it to me I would like to compare what files I have to yours.
