UT2003 problem
Rager03
Hey, Im new here but anyway, I recently bought the Asus V8420 GeForce 4 Ti4200 64MB Graphics card and I having problems with it. In UT2003 It goes down to from the looks of it 9.5FPS when enemy bots are present. Then if too many come along it freezes. Some levels such as Phobos 2 refuse to work, It locks up when the announcer says ''Play''. I have a ATI radeon 8500LE 128MB and it works fine, not as smooth as when the Asus card actually works properly but still...
Any Idea's anyone?
P.S I've tired nvidia det. drivers and Asus's drivers, still no luck.
:frown:
Welcome to AT first of all....
Second from reading your post I would say you need to completely uninstall the 8500 drivers from your system first, (sounds like to me you were using it and then installed the 4200. You can go here and get exact detailed instructions from the forums on how to uninstall. Then install the 4200 with either the 30dets, or new 40's. Then you should be up and rolling just fine.
FYI...
I had problems with UT2003 with my ti4200's GPU overclocked passed 300. Make sure you test this without overclocking first.
-JC
