UT Question: What button to bind "secondary fire" to??
NotoriousJTC
1,406
This had bugged me for a while. I'm relatively new to the UT world.
But where do you guys bind the secondary fire to? My binds are set up basically the way i had em in Quake, with similar weaps binded the same way.
I currently have sec. fire binded to "F". I was thinking maybe chance it to mouse2?
Any suggestions?
BFG10K
22,709
3,003
You should definitely bind it to your right mouse button. Using the keyboard to fire is clutzy.
leeland
3,659
I agree, using the second mouse button works well for me and I use the regular keys w,a,s,d to move around instead of the arrow keys, if you want to pick up some good moves going into a game as a spectator is cool to see how the really good players do it and get some hiding places and moves as well, it is also a nice way to watch people get blowin to bits !!! for the jump it is spacebar. u can try that out and see if it is too your liking, as I am also new to the game this week and would like to hear some other tips from the pro's.......good luck
Magikal
98
In every FPS that I play I bind my keys like this:
Right mouse= move forward
Left mouse= primary fire
Middle mouse= secondary fire
Up arrow= jump
Left arrow= strafe left
Right arrow= strafe right
Right control= crouch
I always have had a hard time hitting the right keys if I do it any other way :0)
YBS1
1,945
129
I have UT bound like this...
Left Mouse: Primary Fire
Right Mouse: Alt Fire
Mouse Wheel: Scroll Weapons
Right Mouse Side Button(Razor Boomslang): Switch to best weapon, usually the Pulse Gun for me. (Eat my burning plasma death! Muhaha) :)
W,A,S,D: Standard Forward, Strafe left/right, and back
Q: Flak Cannon
E: Mini Gun
R: Shock Rifle
Shift: Translocator
Z: Redeemer
X,C: Toss relic/weapon
Alt: Rocket Launcher
Space: Jump
I have some other keys bound for messages, etc., but those are the basic ones.
pen^2
Banned
Apr 1, 2000
2,845
Magikal, I dont see a key for backpedal in your setup... you mean you never back away? :Q
demenion
1,552
Ive been using these general settings for all 'basic' first person shooter games since quake
w - foward
s - back
a - straph left
d - straph right
mouse1 - fire
mouse2 - jump
mouse3 - use item? open door? etc.
ctrl - grappling hook, translocator, etc
space - crouch
shift - walk
q - previous weapon, last weapon used
e - next weapon
f - alternate fire, misc macro,
g - reload, zoom, etc
h - flashlite, etc
v - voice menu, special menu, etc
z - drop tech, powerup,
x - drop misc item powerup, or other key
mousewheel for switching weapons also
numberkeys 1-6 are most important weapons
t - chat
r - teamchat
:D:D:D:D:D:D
GiLtY
1,487
wow, i pertty much use the ones that are already defined when i bought it :Q
all i changed are:
w-move forward
d-move backward
s-strafe left
f-strafe right
a-jump
NotoriousJTC
1,406
Ok, thanks for the tips. I think im going to experiment with mouse2/2nd fire and spacebar/2nd fire, and then jump as either when ive decided.
Oh, one more quickie, is there a way to bind Proxy mines? I think it should be done in the console, but i dont UT uses the same system as Quake.
Jan 5, 2001
40
I use the arrow keys with
Ctrl = Jump
o = crouch
Del, End PGe Down are all diffrent weapons
That way I can aim,fire move and jump all at the same time
shadowfaX
893
My usual config:
Primary fire: mouse 1
Secondary fire: mouse 2
Forward: E
Back: D
Strafe Left: S
Strafe Right: F
Jump: Space
Crouch: A
Change Weapon (too bad I don't have a wheel mouse): Shift
GiLtY
1,487
i have a question about UT:
i got UT from my friend, he burned it for me, and he put the files into winzip, which i have to unzip the files to the computer to play it. But somehow everytime i start/restart UT, it resets everything back to the binds that came originally, how can i change it so it wont reset everything back??
NotoriousJTC
1,406
I dont think you need the CD present to play. Couldnt you just install it(borrow disk from friend) and then just play?
