I did a clean install of UT today. Went to Windows Explorer and deleted the UT folder after I did the uninstall. When I tried to run UT after the install I got the following error:
Assertion Failed: InPos<=Size[File:..\..\Core\FFileManagerWindows.h][Line:57]
I tried to run UT again again and I got the "Ran out of Virtual Memory" error again.
After a few attempts it finally UT started.
Ok, before the clean install I set the Virtual Memory to 300 minimum and 300 maximum. I also downloaded CacheMan and set the settings to UT, Quake.
system specs:
P3 600mhz
128Mb PC100 RAM
V3 2000 @180mhz
20gig HD
I'm at wits end here!!! Please, if anyone can help, I'd REALLY appreciate it.
thank you
system specs:
P3 600mhz
128Mb PC100 RAM
V3 2000 @180mhz
20gig HD
thank you
